Hydraulic Steering - Single Ram - HelpAny >
Old 04-16-2007, 07:36 AM
I probably have a total of about 8 hr's.
Noise Pollution is offline
Old 04-16-2007, 01:05 PM
The right to left turn lock differential will depend on the ram and size (volume) of the helm unit.
The manufacturer should have that info with your kit.
Gary
rdoactive is offline
Old 04-16-2007, 02:34 PM
Originally Posted by boatn70
i will be installing steering real soon! how long is this project taking you guys. barring any issues like this thread addresses.
thanks, sorry to step in....just learning again.
b70
It took me a little longer than 8 hrs. Make sure you really think this through and have all the tools and misc. parts you will need. That is what slowed me down, the little things.
t-islands is offline
Old 04-16-2007, 03:58 PM
Received 1,821 Likes on 907 Posts
Originally Posted by marylandmark
Do you have to run the motors when you do this?
What does that do- power the hydraulic pump?
Yes and Yes.
Griff is offline
Old 04-17-2007, 05:35 AM
mats's Avatar
Most systems require you to turn the wheel quite a few turns in one direction to force the oil/air past the check valves back to the resivour then repeat the process in the other direction. It is easy to have a bubble on one side of the piston if not done properly, the full turn is a little odd. Are you sure the ram is at half travel when the drive is centered, I have found instruction measurements to be wrong. I make it a practice of marking the rams center of travel with the drive blocked center before marking and drilling holes.
Please observe that the geometry of the single ram system is assymetric. Assuming that it is mounted on the starboard side of the drive, turning x degrees to starboard takes more travel by the ram than turning x degrees to port. This has some consequences;
1. When going straight ahead the ram should not be in the middle of the travel if you want to be able to turn as much to starboard as to port
2. I will take more turns to turn to starboard than to port
3. It will be easier to turn to starboard than to port, since you have more leverage
I would trust the manufacturer to have done the math.
mats is offline
Old 04-17-2007, 10:27 AM
noise pollution, I'm planing on adding a hydraulic system to my Prowler. My existing helm was installed with a 20 degree wedge from Sonic to give the wheel less of a vertical position, did you have that and if so how did you deal with it? Also as I recall the original helm was mounted over a fuse panel, did you have any issues installing the new helm? It sure seems you hear of lot's of issues when people add a hydraulic system, are the instructions so poor or does each situation have different variables on each application? Steve
509 SC is offline
Old 04-17-2007, 09:29 PM
I reused the wedge and made a wedge to match it to go behind the dash. Made it out of a hard maple.That way it makes a parallel surface to pull the steering collum and the helm pump up to. I'd post a pic, but not sure haow to do it.
Old 04-18-2007, 11:36 AM
Thanks, I follow you on the inner wedge! Any issues with the fuse panel on the back side of dash mounting the new helm? Thanks, Steve
509 SC is offline
Old 04-18-2007, 03:20 PM
No. I mounted the pump so the lines point down on a fourty five degree angle to the starboard side.
Bolts are at 12, 3, 6, 9 o'clock position.
Old 04-18-2007, 10:12 PM
Thanks, Hope you get everything worked out! Steve
509 SC is offline
Quick Reply: Hydraulic Steering - Single Ram - HelpAny
