Bad valve cover thread >
Old 04-29-2007 | 06:42 PM
gripit's Avatar
Default Bad valve cover thread
I have a new set of Dart Iron Eagles and it turns out that one thread for the valve cover bolts is bad. I tried to rethread with a tap but their is something in their that keeps breaking the teeth off the tap when trying to rethread. Its like a piece of sand or something when it was manufactured. So I gave up trying to retap. What are my options besides taking the head off and taking it back to the machine shop for a replacement?
gripit is offline
Old 04-29-2007 | 08:15 PM
Grip,
It almost sounds like maybe a tap was broken off in it at the factory ? Get a small drill bit, 1/8" should do and see if you can drill the hole a little deeper. Just be careful so that you dont break the drill off too. If so, it is probably ok and you could put a helicoil in it. There is not much room around the hole, but it can be done. If there is a tap or drill broken off in the hole, you will have to find a shop that has an EDM machine to "blast" the broken tap or drill out first
By the way, are you using a good quality tap ? There is a big difference in them. I have found the SnapOn ones the most reliable and strongest as far as not breaking.
Bill Koustenis
Advanced AUtomotive Machine
Waldorf Md
BillK is offline
Old 04-29-2007 | 08:48 PM
gripit's Avatar
I used Craftsman. Should I try a Snap on?
gripit is offline
Old 04-30-2007 | 07:40 PM
Grip,
Its worth a try if you are breaking the Sears taps. Also, are you using any type of cutting fluid .... that will help tremendously. Go real slow, a turn or so at a time, take the tap out and flush the hole out with brake cleaner, then more tapping fluid and go a little further. Also, the holes are usually not that deep, so you may need a bottoming tap too.
And ... there could very well be something stuck in the threads causing the problem. Hard to tell without being there.
Bill
BillK is offline
ThirdBird
Wanted
1
05-16-2008 07:02 AM
CN24
7
12-23-2004 06:19 PM
kmiller
2
03-23-2004 09:37 AM
Cignificant
10
02-07-2004 09:41 PM
CAP071
3
05-07-2002 08:49 AM
