Hatch Actuator >
Hatch Actuator
Hatch Actuator
Old 05-03-2007 | 10:05 PM
Ted G's Avatar
You need to check the volatge at the actuator when it is running. If it drops a lot when it runs then you need to add a relay box/accelerator. I think Eddie Marine makes one or you can wire up your own with 2 DPDT relays. This way you can use heavy gauge wire from the battery to the lift and get virtually no voltage drop-voila, fast lifting.
www.cbpba.com
Ted G is offline
Old 05-03-2007 | 10:40 PM
CP makes a relay box, get it.
ghittner is offline
Old 05-03-2007 | 10:43 PM
offthefront's Avatar
yup ....
offthefront is offline
Old 05-09-2007 | 05:23 PM
speedboatr's Avatar
1BIGJIM
my hatch actuator is 19 ˝” when closed. I think this is the one that is listed as the 12”. Unfortunately the one you have I can’t help you out with. If I talk to anyone that needs the one you have I will pass along your name.
I had a friend recommend taking it to a local company that specializes in electric motors. I had them check it out and it was pretty wore out. They rebuilt it, so this weekend I will be reinstalling and let you know what I find. Using a relay setup sounds like the way it should be set up from the factory
Again thanks for everyone’s help.
Speed
speedboatr is offline
Old 05-10-2007 | 02:59 AM
insptech is right. check the voltage at the lift motor when it's running. If it's low however the most likely reason is a cooroded connector, switch contact, fuse holder or wire splice on the way from the power to the actuator. Fix that and you may be set. A relay box would do the same thing by bypassing old cooroded wiring. It dosen't take much corrosion at that current draw to result in a significant voltage drop.
NightHawk is offline
brassbat
Baja
1
09-01-2008 09:46 PM
duksrule
Baja
0
05-28-2008 08:59 AM
jrocket
08-24-2006 08:27 PM
MACTONITE
Powerquest
5
04-27-2006 07:11 PM
Twin screws
02-14-2003 08:18 AM
