Questions about my Cam..???? Need help!
I just recently had my motor rebuilt and I want to make sure that the camshaft that my engine builder picked out is going to work without a possibility of reversion. I have told a few people about the cam that I have in my motor and pretty much I have gotten mixed reviews regarding the cam in regards to reversion.
Here are my cam specs:
INTAKE EXHAUST
Valve Adjustment HYD HYD
Gross Valve Lift .613 .613
Duration @
.006 Tappet Lift 307 307
Valve Timing Open Close
@ .050 INT: 16 BTDC 48 ABDC
EXH: 56 BBDC 8 ATDC
These specs are for cam installed @ 106.0 Intake Center Line
INTAKE EXHAUST
Duration @ .050 245 245
Lobe Lift .3610 .3610
Lobe Separation 110.0
Comp Cams Part# 11-000-9
Carl Mcquillen Racing Engines
Grind#: CB 3150B / 3150B HR110.0
Please let me know if it is good or bad...? I just installed the motor in the boat but we have not started it up yet so its not too late.
Anthony
INTAKE EXHAUST
Duration @
EXH: 56 BBDC 8 ATDC
INTAKE EXHAUST
Anthony
I'm not a cam expert but the cam you have is a automotive grind,not at all a marine cam and is wrong for what you are doing (If I remember correctly you have a typical 502 with wet exhaust) . Your leaving alot on the table,I told you 4 months ago your engine builder sounded like a car engine builder,not marine engine builder when he told you to discard your rectangle port heads and find some oval port heads but thats already been debated so I won't bring it up again. Call rm builder-585-654-8583,he is even local to you in the rochester area and is a marine cam expert. I'm not picking on you but your engine builder is steering you wrong,Bob-AKA-RMbuilder will pick you out a appropiate cam to salvage your motor build to where you don't end up with a turd,Smitty
