Thru-Hull Exhaust Help >
Old 06-19-2007 | 10:31 PM
Risers or manifolds. Even in a low flow condition, you won't make that kind of steam in the driveway. The engine has to have some real load before you make steam due to a low flow condition. Obviously, a no flow condition would make some steam, but I did see some water flowing out of the pipes. Check the exhaust before it costs you more than a few gaskets.
Rene
oldandtired is offline
Old 06-19-2007 | 11:13 PM
How hot is the water coming out?????? It should be about the same temp as bath water.
Griff is offline
Old 06-20-2007 | 06:05 AM
yea water is coming out....can I ask this question while it may be dumb...what is the purpose of the water going to the risers...the water goes into the bottom of the manifold than travels all the way up...my question is why can't I squueze off the check balls much tighter, really to force all the water through the motor once it gets hot enought to open the thermostat? Could this be my problem...it seems pretty flat!
also to show I do have water coming out this is a picture before the motor reaches operating temperature.
Attached Thumbnails Thru-Hull Exhaust Help-boat-006.jpg   Thru-Hull Exhaust Help-boat-008.jpg
formula18 is offline
Old 06-20-2007 | 06:33 AM
stageharbor's Avatar
Go Big or Go Home
do you have closed cooling? if so i would look into a bravo belt drive seawater pump.
stageharbor is offline
Old 06-20-2007 | 06:54 AM
I wish I did but I do not
Old 06-20-2007 | 11:12 AM
Originally Posted by formula18
the water temp is perfect at 145 during idle and throttle I can keep my hand on the exhaust water for a few seconds before it gets to hot...what do you think steam or smoke?? first 2 at idle 700 next 2 at 1300
You should be able to keep your hand in the exhaust water for as long as you want. It sounds too hot and like it caused by a lack of flow.
From what you say, your engine temp is fine, so look at another area. Check your exhaust. You could have an obstruction inside the risers.
Griff is offline
Old 06-20-2007 | 01:59 PM
I don't know why i didn't think of this before...could this be it...when I got a new water pump pulley they told me that they upgraded it and the pully is bigger...they gave me new belts. now wouldn't that slow down the pump and cause less water to flow to the motor making hotter...hence have more cool going to the riser?????? CAUASING STEAM!
Old 06-20-2007 | 02:11 PM
ljsmith1's Avatar
Bigger Pulley = Slower shaft speed at the pump = lower volume (all other things being equal). If the pulley was made for the pump (i.e. not mismatched), the volume should be ok. The part number of the pump must be specific to your motor - especially if it is aftermarket. Did you check the pump in the drive? If not, you should crack it open and inspect. Make sure the vanes are intact and inserted the right way.
I have a Formula F223 with a 454 Mag Allpha, and the only time I have steam (low quantities) is when I initially fire up the engine when its cold. After it gets up to temp, I have no more steam.
-Larry
ljsmith1 is offline
Old 06-20-2007 | 02:13 PM
I think thats what it is...the pump is from one place and the pulley is from another....I need get my hands on the smaller pully like I orginally had on the motor! I bet that helps.
Pump in drive is brand new
Old 07-06-2007 | 01:43 PM
ttt- What was the outcome on the steam?
CC247 is offline
dna121605
10
04-02-2007 12:17 PM
dyno
12
06-29-2005 09:11 AM
CC247
5
04-14-2005 03:26 PM
32 thunder
06-25-2003 02:28 AM
seanclong
13
02-23-2003 02:05 PM
