When hitting throttle motor is doing weird things >
Old 06-25-2007 | 02:26 PM
Default When hitting throttle motor is doing weird things
Remanufactured 1989 mercruiser vortec small block with a rebuilt quadrajet.
Motor seems ok and idles nice..(excessive steam is my only complaint) I think thats a cooling issue even though I run at 145, now I am thinking it may be related.
When I hit the gas to try and get up on plane it hesitates or lags for i'd say about 3 seconds before going I have to go up about 500 rpms at a time or it just won't move...I believe I am over propped, so that may have somehting to do with it. but its not major. I am seeing up to 4300 rpms so I should probably drop 2-3 dregrees in pitch. But what are some of things things that I should check or change.
I have changed the water seperator as well I installed a high flow fuel pump. The filter at the carburetor is clean as well
formula18 is offline
Old 06-25-2007 | 02:52 PM
If you're getting the hesitation when you open the secondaries, the first thing I would check is the secondary air valve spring. It's probably too loose. I haven't seen one properly adjusted on a rebuilt yet.
Liberator21 is offline
Old 06-25-2007 | 02:59 PM
Check the accelerator pump too.
With the engine off, flame arrestor removed, pump the throttle a couple times while looking down the carb. There should be a squirt of fuel.
rdoactive is offline
JMAASKE
1
09-06-2007 12:55 AM
totalrex
8
08-06-2007 04:08 PM
driveumhard
5
10-16-2004 10:21 AM
Cig Bullet
Pantera
0
07-26-2004 10:07 AM
Scarab3DMC
4
06-10-2003 02:08 PM
