depth finder >
depth finder
depth finder
Old 07-23-2007 | 11:44 AM
I removed the old puck and all the old epoxy. Sanded the area with a coarse grit paper and epoxied in the new puck.
David Stotz is offline
Old 07-24-2007 | 02:50 PM
baja bailey's Avatar
The wire that goes to the puck, does it unhook from the old puck or do you have to cut it??
baja bailey is offline
Old 07-24-2007 | 05:55 PM
SANLEONKID's Avatar
If its when you ar eruning at speed it is caused by the cavitation of air/wate under the hull not allowing a decent signal to the bottom. If its at slow speed see above posts..
SANLEONKID is offline
Old 07-24-2007 | 06:17 PM
offthefront's Avatar
new puck has a wire ...it plugs into the Gauge ...
offthefront is offline
Old 07-25-2007 | 12:58 AM
I am looking at a 90 Baja 250 ES and the depth finder does not work. The original one in the bilge was disconnected and the seller installed a transom mounted one. I think the transom mount ones are just ugly. It too does not work. Can the transom mounted one be removed? What to do with holes? The hull is gloss red.
Engine Co 454 is offline
Old 07-25-2007 | 12:20 PM
Looks like I have to run the new wire to the dash, almost wonderif I should just replace the gauge also and just be back to it all being new.... Thanks alot for all the help guys....
hdtvned
3
08-08-2007 07:48 PM
groundsfordivorce
08-07-2007 07:50 PM
dencam7
1
07-30-2007 12:28 PM
speedchangesyou
4
08-02-2005 01:33 PM
Magicfloat
09-16-2002 04:41 PM
