Which Supercharger is better?
Hi everyone, I have a 30' campion chase with a 500hp,cmi headers(525 php with headers and computer re-programmed). Throttle body fuel injected. It has a volvo dpx outdrive on it and presently runs 71mph on gps with 3/4 of fuel in it. I would like to put a supercharger on it however would like to know which one would be the best and also how much more mph can I gain?
Thanks in Advance
Thanks in Advance
Dustin
Throwing this against the wall.....
Might be easier/cheaper in short term and long term to install a carb'd Whipple system on it.
Custom this and that on an EFI system not being programmed in person can become...well....troublesome.
Dustin you are right about the v-belts and computer, so your saying the 3 inches of clearance is in the front of the closed cooling system or back(closer to the motor).
Bichaum.
B4 you start throwing $ at the engine you may want to talk with someone about the counter rotating props on the lower unit. Because you will probably end up putting 2 larger pitch props at some point you may run into a hydro dynamic issue. I may be wrong, but i seem to remember when Merc had the Blackhawk drive they found out there was a maximum speed on the unit. Do some research.
Wannabe
Wannabe
Whats nice about the efi is we have knock sensors. I didn't want to loose that when I finaly decided what I was doing.
Bichaum.
Wannabe
Wannabe
Thanks,
Dustin
Thanks for all the replies...................so I take it whipple would be able to set me up with something, now the only other question is the drive, what hp is it capable of handling. Now once I know this it'll be get r done.
