OMC King Cobra problem >
Old 08-08-2007 | 07:52 PM
onesickpantera's Avatar
Default OMC King Cobra problem
My buddy's King Cobra has "popped" out of gear a few times. I figured it was the shift cable.
It isn't. When you put the drive in gear you can grab the prop and turn it about 1/4 turn until it fully "locks". Then you can turn it just a smidge(1/4") in the opposite direction and again turn the prop a 1/4 turn. You can do this over and over. It's not the prop hub the prop shaft is turning. I also checked the engine coupler and the input shaft is NOT spinning. So, somewhere between the propshaft and the input shaft the drive is "slipping".
I'm stumped!
onesickpantera is offline
Old 08-08-2007 | 08:32 PM
It must have rung a shaft.
Jim
MOBILEMERCMAN is offline
Old 08-08-2007 | 09:23 PM
Jim
Huh?
Old 08-09-2007 | 06:11 PM
Airpacker's Avatar
clutch dogs smoked if its a pre 1990
Airpacker is offline
Old 08-09-2007 | 06:31 PM
No, it's a cone clutch model. I forgot to mention that.
I'm thinking the cone clutch isn't fully engaging for some reason.
Old 08-09-2007 | 07:30 PM
I just went out and checked my 1990 king cobra and my prop does the same as yours. Mine doesn't jump out of gear. If I can help let me know.
CC247 is offline
Old 08-09-2007 | 09:00 PM
What? You can turn the prop with it in gear? I can't see how this is normal. I know my Bravo doesn't budge and my other friend's cone clutch King Cobra didn't either.
Old 08-09-2007 | 09:19 PM
yup, I put it in gear. Grab the prop and turn it with my hand. It moves 2-1/2" then locks. If I move the prop backwards about 2-1/2" it locks. So I guess you could say there's play. Like about 1/8 of a turn. Maybe mine is screwed up, but it doesn't pop out of gear.
CC247 is offline
Old 08-09-2007 | 09:21 PM
After re-reading your post, could you have a broken gear somewhere in the drive? I've never had a cobra apart so I'm not sure.
CC247 is offline
Old 08-09-2007 | 10:43 PM
It is still running great except it pops out of gear on occasion.
Here's the kicker. Went back to my other friend's boat and if you turn it SLOWLY it does the same thing. So I guess it is normal? I'm baffled. Must be an OMC thing.
ciaoderhead
Drives and Lower Units
12
06-02-2023 03:56 PM
yesrej
35
06-10-2022 01:48 PM
tassie boy
1
08-17-2007 06:28 PM
merlyn1965
08-16-2006 07:02 AM
24Baja
0
09-20-2004 02:13 PM
