help 496 ho
Old 08-13-2007 | 09:11 PM
you are correct. they had to order it anyway so maybe in 2 weeks we can take a crack at it. Im going to New Mexico trout fishing this coming weekend....bl
lakerat is offline
Old 08-13-2007 | 09:21 PM
johnnyboatman's Avatar
you can order it from bam marine and get it this week,i could pickup the boat and do it at my house this weekend if you want.
johnnyboatman is offline
Old 08-13-2007 | 09:27 PM
up to you I ordered the parts online and should be here in a couple days. I will drag it to you if you want. Then I'll owe you...b.l
lakerat is offline
Old 08-14-2007 | 04:35 PM
hp500efi's Avatar
Member #9
Cam sensor is an easy change. The crank sensor is in a spot that makes it challenging to change. Once located, there is one bolt that holds it in place, remove and then rotate and grab the part of the sensor that acts as a handle and start tugging. It is a b!tch to remove but after tugging enough and swearing it comes out. The replacement is slightly different than the one from Merc (at least mine was from BAM). I oiled the O-rings and installed the new one.
Here is my defective one
Member of the Liquid Jungle
hp500efi is offline
Old 08-14-2007 | 08:19 PM
i changed the one on my truck it was a beach had to do it from underneith, the boat look fairly easy.my replacement was also diferent from the orig. butch call me when the part come in.
Old 08-14-2007 | 08:47 PM
will do Jonny and thanks alot. HP500efi thanks for the pics. As I am mechannically retarded that is great stuu. If you have anyu construction ??? I can help with that however....bl
lakerat is offline
TeamPSI
23
12-10-2007 05:23 PM
apexer
11
07-20-2007 07:24 PM
westcoaster
3
08-08-2005 11:24 AM
bn
4
01-15-2005 07:40 AM
NVRENOUGH
3
02-18-2002 12:25 PM
