312 Fastech
Old 08-23-2007 | 06:16 AM
Question 312 Fastech
I Just Bought A 2003 312 Fastech With 496's. Boat Is Great But I Was Curious If I Could Get More Top End Out Of It With A Prop Change Or Any Other Minor Modification.
JEFF CHRZANOWSKI is offline
Old 08-23-2007 | 07:17 AM
Knot 4 Me's Avatar
CMI headers. Minor, but expensive modification. You may or may not be able to pull bigger props after the change.
Knot 4 Me is offline
Old 08-23-2007 | 07:19 AM
t500hps's Avatar
21 and 42 footers
If they are the HO 496's you'll see about 77-78 on the speedo and about 72-73 on GPS. You should be spinning 30P 4 blade bravos through 1.65 ratio B1's. If the props aren't right then you could start there. Minor modifications will get you nothing if the setup is already correct.
The CMI header swap is supposed to be good for 45-55 HP on those motors which would get you 2-4 MPH. For $3,500 per motor I wouldn't call that "minor" expense wise.
t500hps is offline
Old 08-23-2007 | 10:33 AM
BY U BOY's Avatar
http://www.raylarengine.com/
BY U BOY is offline
Old 08-23-2007 | 11:56 PM
CMI's all the way. You will get at leats 4 mph. You will need a prop change if not already at rev limiter. Have first hand experience with that set-up.
Bawana is offline
t500hps
07-14-2015 12:33 PM
jmackin
07-02-2008 11:19 AM
gcoutlaw
08-31-2007 08:35 AM
dave krehbiel
Prop Talk
7
04-25-2007 10:30 AM
Crazyhorse
07-19-2006 12:40 PM
