water pressure questions >
Old 09-07-2007 | 03:09 PM
Default water pressure questions
On the Fountain boats where is the engine water pressure pick up ?
I'm reading high oil temp, 150-160 water temp and zero water pressure on one engine.
ed
Interceptor is offline
Old 09-07-2007 | 04:41 PM
nordic95's Avatar
ed
Mine were on the right hand side of the engine block as you look at the front of the motor.They just use one of the drain ports and add a hose bib and then the hose.Remove the hose bib and flush the hole out with water and a piece of wire.The hole will get clogged over time and make the pressure read zero.
Nordic95
nordic95 is offline
Old 09-07-2007 | 05:04 PM
mine also read zero because the bypass water valve (the southern-engineered double valve on the transom) was jammed. Even though I could turn the round handle, the valve was stuck in the mechanism. To verify this, hook your garden hose to the fitting on the center of the transom, switch the valve over so water flows to the engine in question...
...water should run out of your exhaust if it is opening correctly. (engine is off ) No water out of exhaust means the valve is stuck or broken. Unhook the double valve contraption from the water lines, take the screw-down valve apart to inspect. Mine was jammed, not broken. Carder
Carder is offline
Old 09-08-2007 | 01:07 PM
monstaaa's Avatar
usually if you have a major restriction on the inlet side of the water system, you will destroy the impellar in the raw water pump. over heat and have no water coming out of the exhaust.
if you have 1/4 rubber water pressure hose to the gauge, they usually are on the side of the block as stated and usually fill up with sediment and sand or the like and plug the hose.
if you can remove the hose from the block, keep say a coat hanger handy. remove the other end of said hose from tehe back of the guage and pressureize it using compressed air. if it does not free itself of the obstruction then have someone apply pressure to the guage side while you slowly and carefully, with hose pointed away from your face insert the coat hanger or similiar stiff thin wire into end of hose and the clog should come out. sometimes the clog is a foot or more away.
monstaaa is offline
Old 09-10-2007 | 11:52 AM
Guys,
Thanks for the help. I now know where the water pick up is on the block. I had cleaned those ports in the spring and they were clogged then. I'll get at them again with a piece of wire.
ed
tssteph
3
05-24-2005 12:28 PM
Zanie
5
03-10-2005 10:58 AM
BUIZILLA
2
10-21-2004 06:04 AM
28Eliminator
11
06-22-2004 10:43 PM
CelticPride
6
10-18-2002 08:19 PM
