no water pressure? >
no water pressure?
no water pressure?
Old 09-19-2007 | 08:37 PM
when I was on my way back from the cove about a 1/4 mile out the motor started sputtering and noticed the water pressure guage at 0 and the temp looked normal then not really knowing what was going on I tried running it like that then thats when it started smokin, I opened the hatch and I noticed the coolant tank boiling. The F-up part is that I dont even think my boat has a freakin alarm because It never went off nor did the warning light come on. Give me a break im new to this $hit.
FOXMXPSYCHO is offline
Old 09-19-2007 | 08:38 PM
Oh yea im scheduled for monday and with only 25 hours on it it better be covered.
Old 09-19-2007 | 10:31 PM
Pwrbt33's Avatar
Good luck Bro, let us know how you make out.
Pwrbt33 is offline
Old 09-19-2007 | 10:42 PM
1CE
Default hot fox
been there done that BEST OF LUCK J
1CE is offline
Old 09-19-2007 | 11:09 PM
thanks guys ill post back the details. most likely burnt head gasket, hopefully i didnt warp anything.
Old 09-20-2007 | 04:29 PM
Our 2004 (in an '05 boat) 496 has an alarm that will sound for low water pressure, high water/manifold temp, oil pressure and drive lube level. I have sounded the alarm for low water pressure when packing it up full of sand and it has sounded before it even got hot. Lately I have been getting an alarm at WOT and it comes on when the temp gauge pushes a bit past 180 (I have been told many times by many techs the alarm will sound for temps in the 205-207 range and up). Working this issue out now (possibly due to a scored brass housing on the sea water pump - 500 hours).
The alarm has saved me from damage but even so these engines also have the Guardian mode which will limit the RPMs depending on the condition and put it in a limp mode when there is a severe problem.
jswfl09 is offline
LostinBoston
18
03-26-2006 07:23 AM
BOATMAN302
3
02-28-2006 08:17 PM
Zanie
5
03-10-2005 10:58 AM
28Eliminator
11
06-22-2004 10:43 PM
merlin540
08-28-2002 05:45 PM
