Blower Cam Choice >
Blower Cam Choice
Blower Cam Choice
Old 10-12-2007 | 07:25 AM
Airpacker's Avatar
Default Blower Cam Choice
I'm starting my winter project. 25 Eliminator Daytona. 509 cid,8.5 to 1CR, Edlebrock performer rpm #6155 aluminum heads, B&M 420 blower, 2 850 BG prepped holley blower carbs, CMI E tops.Planning on 5 to 6 lbs boost. Suggestions for cam requested. I want to turn it to 6000rpm . Note: I need a relatively smooth idle due to running a Black Hawk drive. It needs to be able to idle around 700 in gear or docking / trailer loading will be nuts. It already does near 9mph at idle with a 500efi in it.
OK motor gurus, whats the best cam choice for this combination and any guesses on HP and TQ #s?
Airpacker is offline
Old 10-12-2007 | 11:19 AM
Big Cliff
I used desk top dyno for my cam choice. Worked out great.
Only thing I would do is run a different blower. 8/71 blower shop, littlefield, etc. More room to grow and buy a chiller.
Old 10-12-2007 | 11:29 AM
See my reply @ HOTBOAT, the same opinions were given here as well..............
Here's the link for my Offshore discussions.....
http://www.offshoreonly.com/forums/s...d.php?t=164018
ghittner is offline
Old 10-12-2007 | 05:55 PM
Strip Poker 388's Avatar
Rob
You can get 2 diff cam manufactures make you a cam the exact specs and it will run diff.
Ramp profiles,degrees of opening and closing.
I would pm Bob RMbuilder
Strip Poker 388 is offline
inxs01
10
01-28-2008 11:46 PM
scooby94
3
07-26-2007 07:54 AM
f_inscreenname
14
12-25-2006 02:07 PM
OldEliminator
8
05-26-2005 07:57 PM
dyno
15
09-02-2004 02:19 PM
