How to disconnect steering cable, TRS ??? >
Old 11-16-2007 | 10:02 PM
Full Force's Avatar
Default How to disconnect steering cable, TRS ???
I am removing my transom assemblys to have work done, I cannot figure out how to remove the steering cable from the inner plate, I have the mercruiser book but it is not clear how to do it, I don't want to break anything, can anyone help?
Thanks Tim
Full Force is offline
Old 11-16-2007 | 10:13 PM
jhiguy377's Avatar
hope someone responds, like to know also
jhiguy377 is offline
Old 11-17-2007 | 05:31 PM
you have to pull the pin out that attaches to the hydraylic assist steering assembly. Sometimes you can just turn the wheel or shake the drives and it will break free, you may have to do both.
Next, loosen the nut that holds the steering cable to the steering assembly (the one with the grease fitting)
Once thats completely loose, it should slide out fairly easily. With mine I had a clearance issue and had to remove the whole assembly to get the new one in.
For that you have to remove that threaded sleeve that has that nut with the spring lookin' thing on the port side.
The nut thats staring you roght in the face on the hyd. assy. that when you remove it it has another nut inside does nothing, leave it alone.
I hope this helps a little, I'll look at mine tommorow to give a better description.
Dangerous Dave is offline
Old 11-17-2007 | 07:05 PM
Full Force's Avatar
I got it today, thanks for the help, Tim
Old 11-17-2007 | 09:17 PM
J-Bonz's Avatar
Very carfully.............................
J-Bonz is online now
atxwellcraft
1
07-02-2008 04:57 PM
Cigaretteski
Cigarette
2
05-18-2008 11:44 AM
AIR TIME
6
01-05-2007 06:26 PM
myscarab30
4
04-18-2006 08:41 PM
Smitty
Baja
3
08-07-2003 04:06 PM
