For all of you engine guru's
here are the specs for the cam installed on my rebuilds.
226/234@50 - .587/.610 - 112lobe sep I had 502's bored to 509's. Same heads with mild port work and larger valve's (same as hp500's) Flat top pistons, Eddie Marine thunder headers, roller rockers, and I kept the efi system. Had the computers reprogramed by Mark at Performance Marine in Louisiana. My question is... what do you think the hp would be? Take your best guess as I won't be able to put it on the dyno. I had them re-built with longevity in mind and was wondering if I got any more power than stock 502's. |
That looks like the 500EFI cam you're using. I'd guess a little over 500 hp.
Come on Ian that's real world numbers...we're bench dyno'n here! I say 600hp minimum and will last 900 hours!!! :D
Cam is a Crane 731 and just slightly bigger than 500hp cam. It should make 500-520hp at 5200 rpms.
Originally Posted by fantastixvoyage
(Post 2398463)
What's the compression ratio?
My Desk Top Dyno says around 500HP with 8.5:1. |
compression will be lower than stock. would be good for a blower though.
(Post 2398463)
Yeah, what you said:D |
Originally Posted by 5050
(Post 2399044)
My engine builder said with a flat top piston and a slightly bigger bore I should be at the same compression ratio or slightly higher than stock. |
(Post 2398463)
| All times are GMT -5. The time now is 01:46 AM. |
