Need help on Alternators >
Old 02-02-2008 | 11:27 PM
Default Need help on Alternators
Here are the alternators off our boat. All I can find is 140 amp alternetors it says 1 wire. Ok so whats the deal with that? On ours it has a plug with 2 wires a arange wire off of a nipple and a black wire on a bolt. So will these one wire alternators work.
I know I ask some dumb stuff here at times but man I wish I knew somethings about the marine aspect of repair.
Jeff and Jessica
Attached Thumbnails Need help on Alternators-101_1267.jpg   Need help on Alternators-101_1269.jpg   Need help on Alternators-101_1273.jpg
satisfied1 is offline
Old 02-02-2008 | 11:30 PM
Here are the alternators we are looking at
New Delco 140+ Amp 1-Wire Marine Alternator
fits Mercrusier, OMC, Volvo Penta
and many other applications.
100% Brand New!
Alternator - Delco 10SI Series
140+ Amp, 12 Volt, CW, 1-Groove Pulley, 1-Wire
This new alternator is known as a Universal Fit Alternator.
It will fit many Applications.
You need only the main charging wire connected from the positive post of the battery to the alternator output terminal.
Output at idle is 85 amps.
Maximum output of 140+ amps is achieved at 1200 engine rpms.
This is a completely new alternator - not remanufactured.
Comes Complete with New Coast Guard Approved Screens and Cover, 1-V Pulley and Front Mounting Bolt. 6 grove Pulley Available on Request.
Interchange numbers:
API Marine: 20051
ARCO Marine: 20102
Delco: 1100576, 1100577, 1102393, 1102496, 1105478
Mercury Marine: 56045, 59755, 69729
OMC: 983424, 983836, 988247
1 year warranty - no hassles - no fine print!!
http://cgi.ebay.com/ebaymotors/NEW-1...ayphotohosting
Attached Thumbnails Need help on Alternators-10si%2520mariney.jpg   Need help on Alternators-10si%2520mariney%2520rear.jpg
Old 02-02-2008 | 11:31 PM
So I guess what i am asking will these things work on our 500 efi engines
Old 02-03-2008 | 12:37 AM
sunchaser796's Avatar
Do not alter or change your alternator. Your ecm is set up to be use with a certain alternator. Stick with the same thing that you have now. And use all the wires that are on the engine. Unless you wanna but an ecm which I don;t think you wanna. Trust me on this. I work for a premeir mecury dealership !!
sunchaser796 is offline
Old 02-03-2008 | 12:38 AM
BE very carefull what you buy from e-Bay
Old 02-03-2008 | 10:02 PM
If you want the merc replacements you could call Mel Riggs at Riggs marine. 920 872 2728
Not sure how close you are to him but he ships and might have them in stock
RonS is offline
Old 02-04-2008 | 03:43 PM
Croozin2's Avatar
If I remember right, his original issue was needing a higher amperage alternator which if he goes back with Merc parts he'll be in the same boat (pardon the pun). The charge rate of the alternator shouldn't have any effect on an ECM. Now, if the field or sense wires aren't connected (as in the 1-wire setup) maybe that will have some effect. I put 1-wires on my old carbed motors. They are just self-exciting units.
Croozin2 is offline
Old 02-05-2008 | 07:54 AM
dbelectric on the web. Send him a pic and maybe he can match it or upgrade your units. He will be way cheaper and has good quality.
kennyo is offline
Old 02-05-2008 | 08:00 AM
Audiofn's Avatar
Charter Member #232
Take thos alternators that you have to a good rebuilder. Ask them to rewind them for more output. I have had this done in the past.
Put your best foot forward!
Audiofn is offline
waterblaster
1
07-28-2006 04:53 AM
CN24
26
12-27-2004 08:28 AM
mopower
3
12-09-2002 05:37 PM
delsol
3
07-30-2002 11:23 PM
