Offshore Water Pickups >
Old 02-29-2008 | 05:55 PM
Default Offshore Water Pickups
Has anybody ever installed offshore pickups on a 382 non-step ? If so where did you mount it and what kind did you use ?
thanks
joby
formula 382 sr-1 is offline
Old 03-13-2008 | 11:09 AM
Anyone ?
Old 03-13-2008 | 11:49 AM
Shouldn't be any different than any other straight v bottom. Mount them as close to center as you can.
Griff is offline
Old 03-13-2008 | 12:09 PM
The problem is that I have a small notch that is only 1 3/4 high and I can not find a pick up that small. Do I mount on the transom above the notch if so how long do I make it ?
Attached Thumbnails Offshore Water Pickups-img_2357.jpg   Offshore Water Pickups-img_2358.jpg   Offshore Water Pickups-img_2359.jpg
Old 03-13-2008 | 12:18 PM
Strip Poker 388's Avatar
Rob
My 2005 5t00efi Whipple kits came with a plain round tube type, I call Dustin since I was going to run both innercooler on one pickup and strainer and he recommended the Imco offshore style.as seen on my boat.
If I was going to replace my pickup,I would buy the one from Teague now, its a nice looking piece and is adjustable,rob
Strip Poker 388 is offline
Old 03-13-2008 | 02:08 PM
Don't know what to tell ya on that one. Might have to get something custom made.
Griff is offline
Old 03-13-2008 | 11:31 PM
Rob
see if Teauge will make ya one with a longer slip tube and ya can cut it if needed.Or make the J part longer and at a 45 to catch the bottom of the notch
I ve had real good luck with gettng reasonable stuff made from Eddies and on other stuff his powder coat looks better than most ive seen
Prater
7
09-09-2008 06:03 PM
formula 382 sr-1
03-17-2008 07:10 PM
teddy38
26
03-13-2007 09:22 PM
bshzba
0
11-21-2006 08:29 PM
Leathl_WS6
Sutphen
0
07-11-2006 07:07 AM
