Capping TRS gimble exhaust hole >
Old 05-14-2008 | 06:45 AM
Default Capping TRS gimble exhaust hole
Im looking for a simple way to block off the gimble exhaust hole to keep water from flowing into the inner transom plate. Anyone have any suggestions? Does anyone make a simple capped rubber boot that would slip on and thighten with a hose clamp?
THRILLSEEKER is offline
Old 05-14-2008 | 12:58 PM
There are block off plates available. Years ago though, I did the thru hull conversion on my Scarab. I simply went to Home Depot and purchased heavy duty rubber caps as you stated. I installed them with two heavy duty SS hose clamps(each), also available from Home Depot. Only cost a few dollars, and the boat stayed that way for years... until I sold it.
Darrell.
DMOORE is offline
Old 05-14-2008 | 04:40 PM
jhiguy377's Avatar
I did what dmoore did; I also added some silicone type sealer around the cast inlets on the inner transom plates(which is what I think you're talking about). good luck - jeff
jhiguy377 is offline
THRILLSEEKER
5
03-31-2008 08:07 AM
Buddy OO
Drives and Lower Units
5
12-17-2007 10:13 AM
G Man
7
08-06-2007 11:14 PM
jeff1000man
02-27-2007 09:45 AM
stecz20
04-28-2006 03:50 PM
