exhaust manifolds >
exhaust manifolds
exhaust manifolds
Old 06-15-2008 | 12:37 PM
Default exhaust manifolds
Just started a new rebuilt 350 motor and found lots of smoke coming from bank 1 exhaust side. i removed the water feeds on the exhaust manifold and riser for bank 1 and the smoke went away and i felt exhaust pressure coming from the riser water feed port. I think this possibly means the exhaust manifolds are bad??. does this sound right. If i removed both water feed on the exhaust manifold and i can feel exhaust pressure coming from the water feed ports then there is a leak. I would imagine i should not feel anythinf i the water poerts with the feed disconnected.
prostockcat is offline
Old 06-16-2008 | 09:32 AM
hoozeyurdaddy's Avatar
at the end of the exaust manifold, the water and exaust come together, there is no vavle on the water portion to keep exaust from flowing back into the water portion, getting exaust pressure out the waterport when disconnected would be a normal thing, unless it a full dry exaust sys.
hoozeyurdaddy is offline
Old 06-16-2008 | 11:02 AM
Is the engine on a stand or in the boat? You would get the pressure back through the water inlet if the exhaust was making back pressure on the part of the exhaust where the water normally exits the riser. (running through the transom or prop will cause the back pressure)
'smoke' or steam? New manifolds and risers? Or did you make the mistake of using the old ones?
two-rocks is offline
Old 06-16-2008 | 07:33 PM
Smoke and steam out of one side of the motor and i did use the old manifolds and risers
chaparral 2550sx
08-20-2007 01:08 PM
35 White Lightning
Fountain
1
04-16-2007 11:19 AM
rssteiny
2
03-13-2006 11:54 PM
Andy
8
02-08-2004 04:12 PM
excaliber
4
09-15-2002 12:47 PM
