need help on trim tabs >
Old 02-26-2002 | 11:34 AM
mattyboy's Avatar
Question need help on trim tabs
anyone out there have a link or a tel number to
boat leveller trim tabs thought they were in St Louis
need to get a gauge for my setup (hydraulic) or will a gaffrig
gauge do the job?
thanks
Mattyboy
mattyboy is offline
Old 02-26-2002 | 03:01 PM
Ron P's Avatar
Enjoy the show
Are they Bennett tabs? If so contact them for hydralic or electronic indicators. Otherwise use a blue water panel with the moving indicators that use push/pull rods from the tabs to the dash.
Did you contact the manufacturer yet?
Ron P is offline
Old 02-27-2002 | 12:36 AM
Default Boal leveler
If I am not mistaked thier address is on the oil bottle mounted on the transom. If not, perhaps call a Baja dealer, they use them ALOT thier boats.
Troubled 26 is offline
Old 02-27-2002 | 06:48 AM
Iggy's Avatar
If you do have Bennett tabs I found that Stainless Marine has a system designed to work with the Bennett tabs as well as others.
Iggy is offline
Old 02-27-2002 | 08:05 AM
mattyboy's Avatar
Thanks guys!
that's the name of the tabs boatleveler, they work fine just want
to get an indicator so I don't always have to guess where they are.
mattyboy is offline
Old 02-27-2002 | 08:31 AM
olysan
They are in St. Louis. Here's a link:
http://www.derema.com/manufacturers1...atleveler.html
Regards
Mike Olson
26sonic
Sonic
8
06-23-2009 09:14 PM
dloftis
Baja
8
03-12-2009 08:08 AM
paxtonsc
8
04-29-2007 12:21 AM
Hot Boat
17
03-31-2002 06:00 PM
dallas01
Baja
11
03-23-2002 10:33 AM
