SBC valve covers >
SBC valve covers
SBC valve covers
Old 06-25-2008 | 01:02 AM
Angry SBC valve covers
Where in the world can I purchase "tall" small block chevy valve covers that will work with GIL exhaust....
HELP!!!!!
JETFIXR is offline
Old 06-25-2008 | 03:56 AM
Scott B's Avatar
I had to get spacers to make my tall covers work with stainless marine exhaust...
Scott B is offline
Old 06-25-2008 | 05:12 AM
Are you having problems finding vavle covers that will fit over the valve train? Or problems with clearing the manifolds?
I bought spacers from Hardin. I wouldnt reccomend them, I opened the box last night and theese things are half inch thick plates of steel. Each piece has between 1/16 and 1/8" rocker from end to end.
THRILLSEEKER is offline
Old 06-25-2008 | 12:37 PM
Hello thrillseeker I noticed your post this morning in regards to the exhaust spacers you purchased. I pulled all of our others off of the shelf and they seem to have about a .030 variance in the overall length. All of these are maunufactured using a nitrogen laser to reduce heat during the manufacturing process and .030 is about as tight a tolerance as can be held. I would suggest that you return the units you have that you are unhappy with because it seems as if they are out of specification. We will gladly accept the parts in a unused and new condition for return. We pride ourselves in quality prodcuts and want you to be satisfied. Billet aluminum units could be CNC machined for you to a exacting specification while the cost would be near double that would assure you the perfect part.
Best regards
Hardin Marine
Hardin Marine is offline
Old 06-25-2008 | 12:43 PM
I have the same Q as thrillseeker has. Do you need the tall covers to fit over roller rockers or ? I've run standard covers with roller rockers before, after grinding the drip tabs off...
VetteLT193 is offline
Old 06-25-2008 | 09:06 PM
With some grinding and a thicker gasket they will clear roller rockers.
Attached Thumbnails SBC valve covers-img_9842.jpg   SBC valve covers-img_9845.jpg   SBC valve covers-img_1997.jpg
formula 382 sr-1 is offline
Old 06-25-2008 | 09:13 PM
Best regards
Hardin Marine
I will return them to CP Perf. Thank you for your concern and response. If used with iron heads and very thick gaskets they would probably work. I just dont see it happening with aluminum though. Ive had great experiences with various other Hardin products in the past, this time it just didnt work out.
Old 06-26-2008 | 02:12 PM
BRIAN73's Avatar
Hardin Spacers,
The only solution for my exhaust problem as well.
Heavy but worked just fine
BRIAN73 is offline
Big Block Billy
7
10-26-2008 04:26 PM
BLOWN85
2
03-02-2008 08:46 AM
sonic28
8
05-07-2004 08:24 PM
dma251
4
02-11-2004 11:28 AM
treatj24
4
01-21-2003 02:02 AM
