500hp carbed 500efi >
500hp carbed 500efi
500hp carbed 500efi
Old 07-06-2008 | 12:31 PM
Default 500hp carbed 500efi
I was wondering what does it take to change a carbed 500 to a efi 500 and is it worth doing.
ubet28 is offline
Old 07-06-2008 | 03:20 PM
not a real big deal to do, just depends on what you are trying to do. the carb set up would be easier and cheaper to deal with for performance mods, just going to need good intake/carb, a lower psi elect fuel pump, and a change to a aftermarket distributor would also help...Rob
ezstriper is offline
Old 07-06-2008 | 03:27 PM
hoozeyurdaddy's Avatar
you would need to find a COMPLETE 500efi sys. incl: distributor and fuel pump. if your carbed now, it probably is not worth the cost of doing it for what is gained.
hoozeyurdaddy is offline
Old 07-06-2008 | 03:36 PM
500efi also uses a different cam. Not worth it imo.
Griff is offline
Old 07-06-2008 | 03:55 PM
offthefront's Avatar
spend the $$$ on fuel ......
offthefront is offline
Old 07-06-2008 | 07:35 PM
Thanks everyone. i guess i am just a little intimidated by the carb as i have always had efi. So you guys are saying there is somethings i will need to change with the motor even if i do leave it carbed. Thanks Jeramy
ubet28 is offline
Old 07-06-2008 | 08:13 PM
If it is not broke do not try to fix it !!!!!!!!!!!!!!!!!!!! Just turn the key and enjoy the ride .
Jeff P31 is offline
Old 07-07-2008 | 12:01 AM
MM1
If you are intimidated by a carb you sure dont want efi.
MM1 is offline
Old 07-07-2008 | 05:15 AM
you missed the part where he said he has always HAD efi. once you have efi motors you never want a carb again ever.
stevesxm is offline
Old 07-07-2008 | 06:54 AM
damn I guess I was reading dislexic !!!! well was a long weekend !!!
ubet28
1
10-20-2008 04:10 PM
speediseverything
11
09-22-2008 11:49 AM
ubet28
27
08-10-2008 12:03 AM
Croozin2
7
08-15-2007 11:55 AM
outlawinil
13
06-18-2003 03:21 PM
