Drive not trimming out >
Old 07-07-2008 | 08:09 AM
Default Drive not trimming out
Replaced a leaking line going to my ram last week, and now the drive still doesnt want to go up. It will go up and down fine while at rest, but underway it will not. Could there be air in the lines? How would I go about bleeding the system?
MILD THUNDER is offline
Old 07-07-2008 | 08:29 AM
hoozeyurdaddy's Avatar
the sys. is self bleeding, you sould not have to do anything but run it up and down a few times, make sure your oil tank is full, if it's not coming up under way either there are lines that got crossed somewhere or the pressure relief valves in the valve body are not working, check your lines for proper routing and then pressure check the sys.
hoozeyurdaddy is offline
VelocityRick
Pantera
15
04-25-2008 05:54 PM
NoQuarter
Prop Talk
5
05-04-2007 01:39 PM
RazorsEdge
Superboat
26
05-19-2006 06:48 AM
boot
08-18-2003 04:37 PM
Steve_H
11
07-24-2003 09:56 PM
