used prop ??
syringa,
Im going to try this on my 99 20'wellcraft excalibur with a 7.4mpi and bravo 1 the prop I have on it now is a mirage plus 48-13702 21p. Im putting a thru hull exhaust on it now and wanted to take advaantage of the rpms. is there any problems with switching these props?
crmax>. Should be no problem at all. If you don't already know of it Hill propellers has a great speed/slip calculator. at www.hillpropellers.com. just first put in good known numbers from your setup and try different variables. If you haven't done it before the results may surprise you
MIKEHTMSR24
07-22-2002 03:18 PM
