-   -   500hp carbed (https://www.offshoreonly.com/forums/general-q/190641-500hp-carbed.html)
ubet28 07-09-2008 07:06 PM
500hp carbed
I just bought a 500 hp and was wondering were to start with getting more power out of it. So if someone could give me some pointers and what to do that would be great. Thanks Jeramy
Also what prop should i use? I have a 25 outlaw running a bravo one drive a 23p mirage plus 3 blade.
baja36ft 07-09-2008 07:38 PM
what year is it??
ubet28 07-09-2008 08:27 PM
I am not sure it is carbed and is the one that is on here for 8500.00 like the 8 th one down in the classifieds motor section
formula 382 sr-1 07-09-2008 09:13 PM
AFR heads and a camshaft from Rmbuilder.:drink:
jryan26 07-09-2008 09:55 PM
741 crane cam, dominator carb and port the heads.
axapowell 07-09-2008 10:06 PM
If it's a Gen VI, I'd go with the stock carb and intake, AFR 315 CNC'd heads, Crane 168741, 1.8 Crane Golds on the intake and 1.7 Crane gold rockers on the exhaust, new lifters, Isky valve springs, CMI Elbow tops, and a HVH 1" Super Sucker carb spacer....620+ Ask me, I've got 2!
Dave
Canada Jeff 07-10-2008 06:15 AM
First place to start is heads. Either port the stock ones, Or buy new aluminum heads. Then cam it up !
ubet28 07-10-2008 12:28 PM
OK as for the heads which is the best for my motor and were do i purchase as with the cam. I think the only problem that i am gonna run into is that i just bought a set emi exhaust and i am pretty sure they do not recommend beefing up the cam.
If you guys could link me to some decent places to find this stuff that would be great and roughly how much is this gonna cost?
Thanks to all of you that are taking time out to help a fellow boater out
formula 382 sr-1 07-10-2008 06:28 PM
Pm rmbuilder tell him what you have and he will make you a cam . The price was $375 for the stick. :cool-smiley-011:
Thunderstruck 07-11-2008 09:47 AM
Amen, call RMBuilder. Bob will set you up with no BS and will stick with you through the whole project. I have 2 600 hp reworked carb 500 hps with Bob's heads, cams, etc. Great torque and picked up 10 mph in the boat.
