help with harch actuator >
Old 07-29-2008 | 06:30 AM
Originally Posted by Strip Poker 388
theres a few threads on this,the one I bought wasent sealed
Great image SP...does anyone have an electrical schmatic of how that works? I've fewled around making my own, but keep creating a latching circuit.
Naughty Kitty is offline
Old 07-29-2008 | 07:17 AM
Dave M's Avatar
Veteran: Navy
Here's one I got from somebody on Speedwake.
Dave M is offline
Old 07-29-2008 | 08:10 AM
Registered User
People typically use two of the Bosch relays in parallel since they're readily available and cheap. You can get larger DPDT relays but they can be expensive. The biggest reason to use a relay is that low voltages are way more susceptible to transmission losses than higher voltages. Running all that wiring in 8 gauge (back & forth twice for each one) and then finding a switch big enough to work reliably is way more complicated and expensive.
Chris Sunkin is offline
Old 07-29-2008 | 11:40 AM
Great post guys...
Dave have you tested that arrangement? I bought a single relay from Radio Shack and figured I could just use it to raise the hatch, and low power on the lower would be fine. The way I read the schematic, when raising terminals 30 & 87a are broken on the energized relay, but shorted on the relaxed relay? this is what messed me up on the Radio Shack relay, as I could never get ground back to lower the hatch.
Old 07-29-2008 | 12:08 PM
Strip Poker 388's Avatar
Rob
I was under the impression that one relay was norm off and the other was norm on
Strip Poker 388 is offline
Old 07-29-2008 | 01:17 PM
Wally's Avatar
Were doomed!
Guys, i made that schematic up orriginaly and someone over on speedwake filled i the wire gauges later....the way its wired up the relays always have a ground on them when not energized....its only when you give the relay its trigger does it switch over to the 87 terminal to give power to the hatch actuator...
-Wally
Wally is offline
Old 07-29-2008 | 03:06 PM
That makes sense..thanks Wally
Old 07-30-2008 | 09:03 AM
Wally's Avatar
Were doomed!
Naughty Kitty....you can make a single relay work for what you have in mind....give me a little time and i'll draw up a new schematic for ya......this is assuming that your dash switch is wired like a typical switch and reverses the polarity of the wires when its working.....
-Wally
Wally is offline
Old 07-30-2008 | 09:54 AM
Wally's Avatar
Were doomed!
ok try this setup....
-Wally
Wally is offline
duksrule
Baja
0
05-28-2008 08:59 AM
Fast Forward
Powerquest
10
10-08-2007 07:20 PM
jrocket
08-24-2006 08:27 PM
MACTONITE
Powerquest
5
04-27-2006 07:11 PM
Twin screws
02-14-2003 08:18 AM
