Teague - World 509 Block Ring Gear >
Old 07-25-2008 | 08:11 AM
RICHARD CUNY's Avatar
Default Teague - World 509 Block Ring Gear
GOOD MORNING GROUP
Once again any help would be appreciated,ring gear went again after three days first one lasted one month. I hade the ring gear and starter replaced last week.
Rich
RICHARD CUNY is offline
Old 07-25-2008 | 08:48 AM
Airpacker's Avatar
If you are tearing up ring gears, I suspect you have a starter shimming issue.
Airpacker is offline
Old 07-25-2008 | 03:47 PM
THANKS AIR PACKER
I had this motor shipped across country from CA. it fell of the block under motormount shifted foward and landed on the starter and after the ring gear went it was descovered that the starter bolts were bent. finding this i was comftorable with that. Now three days later the same problem
Rich
Old 07-26-2008 | 08:21 PM
Rich,
Are you using the correct starter bolts ? The correct ones have a "shoulder" that sits in the recessed hole in the block and keeps the atarter from shifting position. If you just use a plain 3/8" bolt, the starter can move. Also, there is a procedure to check and shim the starter. Is this a "normal" GM starter, or a mini starter ?
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
BillK is offline
Old 07-26-2008 | 10:08 PM
Panther's Avatar
Frank's Marine Service
sometimes the starter bolts are just a little too long and you need to put a washer underneath. Be sure to check for proper length.....
Panther is offline
RICHARD CUNY
10
08-30-2008 11:56 AM
RICHARD CUNY
3
07-25-2008 03:42 PM
RICHARD CUNY
5
07-10-2008 05:37 PM
Firewalker
15
07-01-2003 01:51 PM
