Fuel pump pushrod
Will I be able to use a stock fuel pump rod on my steel billet camshaft? I remember reading somewhere , that maybe a stock rod would wear down the pump lobe on the cam.
Someone set me straight!!
thanks
Travis
thanks
Travis
.. thanks cord..
I just found one in PAW that has a bronze tip for steel cams. It's a lightweight rod though, but this is the only one i can find
Travis
"your a 3/4's of a mile ....call the ball"
Travis
Official OSO boat whore
Now it's been a while...but I believe that your rod installation will go easier if you thread a bolt through the front of the block to gently jam it in place. Just be sure you use an appropriate length bolt later on-you'll end up with a oil leak if you leave the hole open. Too long of a bolt and...
well cord I am **** drunkand I can't even tel what the F&^@#K your talking about... man All I am going to do is ioler her up and slamit in the hole hole.. no problem shte last times LOL!
thanks man..
travis
thanks man..
travis
BillR
11
07-29-2022 06:31 AM
Rage
6
07-31-2007 09:45 AM
