Biggest HP on pump gas? >
Old 11-17-2008 | 06:11 PM
  #91
Whipple Charged's Avatar
Originally Posted by RunninHotRacing158
Dusty are you going to bring the 9.8s back around seeing your thoughts on the PSIs they are'nt worth a hill of beans ... Or do you still have them ???? See ya in Miami
Yes, were working on it and yes, its far superior. @ 1.6 overdrive, 10,000 engine rpm, it makes 60psi on a alcohol 540ci BAE engine. That was 3500hp on methanol. PSI had to turn 2.25 and had 7.5psi more boost to get the same power.
Whipple Charged is offline
Old 11-17-2008 | 06:31 PM
  #92
HotPursuit's Avatar
Originally Posted by Whipple Charged
20,000rpm will produce nearly 30psi on 600ci motors with Pro1 heads. This equals 8 high dollar ash trays.
I was stating that on your site the 8.3s at 12,000 produced the same cfms as the 5.0s @ 20,000
3250 i did see the 30# of boost
ASh trays
HotPursuit is offline
Old 11-17-2008 | 07:31 PM
  #93
make plans for breakage 3 months in advance
Now thats funny BIG Daddy but we aint gunna break
Not refering to the engine, just the superchargers. Then try to get 2 the same. Just put some feeler gauges between the rotors and see, then measure rotor to bearing plate clearance. The 980 is almost twice the size of the PSI and is a true axial entry, there really is no comparison.
Old 11-18-2008 | 09:26 AM
  #94
[QUOTE=Whipple Charged;2741492 just think if my cart had whipples on it [/QUOTE]
Well if my cart wudda had Whipple's, it clearly would run slower but show more power on the dyno!
Well get workin on it BIG Daddy and dont fill it up with that Cali gas we'll get ya some 118
jk
Old 11-18-2008 | 11:50 AM
  #95
OUCH Dusty .... you mean to say Roger does'nt use Geometrical Tolerances any more ???
Old 11-18-2008 | 12:57 PM
  #96
Strip Poker 388's Avatar
Rob
We did, we had the 9.8 liter male driven supercharger. We built what we felt would still be manageable in multiple applications.
blue one looks heavy?
Strip Poker 388 is offline
Old 11-18-2008 | 05:14 PM
  #97
HotPursuit's Avatar
Ya, have fun with distribution! And I think HP already went down that route. Also, better order now, only takes 3 months to get them, and if you need a part after, just make sure to make plans for breakage 3 months in advance!
Not to be a D**k but theres alot of complaints in the industry about warrantys and kits that dont work.
You started this sh*t with knocking your competitor instead of your product speaking for its self.
I dont see Blower Shop,Little Field,Psi and all your other compitition downing your product, makeing claims that cant stand behind.Ill say it again and agian show me 1 comparision in a true life condition and shut me up.
No one has posted on this thread as of yet and gave me a hard # on speed gained when they went to your set up.In fact the 38.8 that was tested fell way short of speeds that the boat should run with 2400Hp
In fact that set up should run 140-150 all day long with 850sc race packages.
Now you need more details about my set up. Like I stated before More HP in my hull will equal more speed, damm Im running a hull that was a race boat for 2 different race teams and holds National and World titles. JC and ByrdMan ran 190 in a 46 former race boat with big power and psi blowers.Im thinking 1550 + so. If I pick up 200-400 hp I should see 10-20 mph easy if not Peter has never built a championship
race boat.
Old 11-18-2008 | 05:20 PM
  #98
HotPursuit's Avatar
The Kramer 388 Skater has Teague 1200EFI's with our W305ax superchargers. The boat is built for Lake Tahoe, 6500ft and has the same pulley's as sea level, negating 3-4psi of boost @ Tahoe. Therefore it's prop/gear combo is setup for just that.
I didn't dyno the motors, but when we dyno, we use the proper correction factor. By the way, instead of correction factor, you should mention "cali" gasoline, just about the worse in the 50 US states. And the motors do make 1200hp, actually a touch more.
So no testing was done before they do a full blown article?
Old 11-18-2008 | 05:21 PM
  #99
If I remember right Nasville Cat had many problems and were repaired not long before the crash.
race boat.
40FlatDeck is offline
Old 11-18-2008 | 07:32 PM
  #100
Keith, I don't build boats and have no part in the magazine articles. I only know about it because it has the supercharger and I did the ECM programming. The boat was tested and setup at and for Tahoe. They brought it down for the test. I do not know why they didn't change gears, not my boat. Write a letter to Powerboat and ask them, or call Bob Teague.
Dustin
