Biggest HP on pump gas?
#71
I was sick not to make the run. The video looked and sounded great.
I had heard you were selling your SC set up which has to say alot for your comfort level with the new Whipples.Looks like you also went EFI. Having to increase gear and prop size tells me you have increased HP and torque. I do like acceleration!!! Thanks for the updated information.
Check out the Vid on Boat freaks @ fun run Badd azz
A friggin rocket ship on water
#75
#77
contentious rpm &max cfms
5.0 LTR 18,000 20,000 3250
8.3 ltr 11,000 12,000 3250
#78
#79
I was at about 12800 rpm blower speed to make well over 1300 hp on 93 octane with a pretty decent size hyd. roller in a 598 ci. That was at 14.7 psi boost. It only took another 8% to make over 2.5 psi more boost at 6400 rpm.(90 bot 48 top vs. 90 bot, 46 top) It came on pretty strong and pretty quick with rpm for only 2 teeth different.
Eddie
Eddie
#80
