Drive Temperature Sensor >
Old 03-29-2009 | 10:43 PM
  #101
Rage's Avatar
Originally Posted by fireboatpilot
Rage that sensor you threaded down to the drive plug thread, does it seat in the drive properly so it won't leak? Looks good though. Hopefully the stainless one can be modified the same?
Yes it seals just fine. It is the electrical grounding issue that sucks with that design sensor. We just need a machinist to say if the Gaffrig stainless sensor can be chucked up in a lathe, even though there is a wire pigtail out the back, and cut the necessary threads. Then it is $14 sensor plus machining cost. to produce a usable sensor for the drives
Rage is offline
Old 03-30-2009 | 08:49 PM
  #102
Mr Gadgets's Avatar
Charter Member #601
Rage,
That was the answer to my question. I wanted to know if the sensor had enough meat on it to cut the new threads.. good job.
I will try and buy a couple of the Gaffrig and see what my guy can do with it..
Dick
Mr Gadgets is offline
Old 03-30-2009 | 11:19 PM
  #103
US1 Fountain's Avatar
Ginger or Mary Ann?
Just tuck the wires inside the chuck or collet. Chasing threads uses a slow rpm, so even less of an issue. I've done some high speed turning wires and no problems.
US1 Fountain is offline
Old 03-30-2009 | 11:32 PM
  #104
I am glad it works for ya !!!!
DareDevil is offline
Old 03-31-2009 | 05:01 PM
  #105
Mr Gadgets's Avatar
Charter Member #601
I just ordered a complete gauge kit and an extra sender... We'll see how it works out, but I think it will not be a problem to turn it down with the wires...
Old 03-31-2009 | 05:41 PM
  #106
Rage's Avatar
That is what I thought but I wanted some one with first hand knowledge to confirm it.
Rage is offline
Old 03-31-2009 | 05:44 PM
  #107
Rage's Avatar
Originally Posted by Mr Gadgets
Rage,
Dick
Well the brass Livorsi sensor that I did has enough meat. The stainless Gaffrig probably does but will not know for sure until some one tries it.
Rage is offline
Old 03-31-2009 | 08:50 PM
  #108
Mr Gadgets's Avatar
Charter Member #601
That's why I bought an extra..
I need a sensor after my cooler in the boat any way and that will be 1/8" pipe.. I do want to put on in the drive to compare temps..
Old 04-01-2009 | 12:20 AM
  #109
Rage's Avatar
Please let us know how it works out.
Rage is offline
Old 04-01-2009 | 02:28 PM
  #110
Mr Gadgets's Avatar
Charter Member #601
I will.
