Drive Temperature Sensor >
Old 12-04-2008 | 12:22 PM
Rage's Avatar
Originally Posted by daredevil
Yes on page 5 i think he says it runs 20 degree cooler then without the shower.
Sorry. First time on Speedwake.com and did not initially recognize the paging scheme. Actually the one guys drive temperature did not change from 270F at WOT but now looking into if the shower is set up properly. Another guy said that he had documented 20F drop in drive oil temperature. Thanks.
Rage is offline
Old 12-04-2008 | 12:58 PM
Rookie's Avatar
I hope that was a little informative read, I've been meaning to get back and see if there was any updates for this year.
Rookie is offline
Old 12-04-2008 | 05:55 PM
Trippin's Avatar
I firmly believe in drive showers, they substantially assist in the cooling of the upper drive during extended full speed runs. For someone who just puts around the lake and gets on plane once in a while it's not worth the investment.
Trippin is offline
Old 12-05-2008 | 12:05 PM
Rage's Avatar
It was informative to the degree it flads the fact that one should be aware that the drive oils can get hot with enough hp but is very limited on details as to drive type vs hp vs oil temperature vs drive shower type vs oil cooling performance. Hopefully such info is out there and will show up on this thread or others eventually.
Rage is offline
Old 12-05-2008 | 02:07 PM
Rookie's Avatar
I believe that the best thing to take away from that thread and reading gages in general is: You know the temps and pressures that your stuff runs at during your normal operations; Idle, Cruise, and Beating the s#it out of it. If something is all of a sudden different it gives you an opurtunity to shut down before a little issue becomes a serious issue.
Rookie is offline
Old 12-05-2008 | 02:44 PM
eastsideoffshore's Avatar
We Have run drive temp guages on a fiew boats on stock power 160 to 220 ,on big power 140 to over 300 but it saved drives ,pull out at 270 and they hold up pretty good .livorsy told me they are not made anymore I found one in texas to replace a bad one ,the pick up is veary fradgle and get damaged when the gears break .
eastsideoffshore is offline
Old 12-08-2008 | 10:36 PM
Rage's Avatar
Do the drive oil temperature sensors fit in the Bravo's upper vent/fill plug or is it necessary to drill and tap a seperate hole for the temp sensor?
Rage is offline
Old 12-10-2008 | 01:44 PM
Rage's Avatar
I called Gaffrig also. They stopped carrying the drive oil temp sensors that screw into the bravo oil fill/vent plug hole.
Do you know of anyone/anywhere that still has the oil temp sensor for the Bravo drive?
Rage is offline
Old 12-10-2008 | 11:22 PM
Rookie's Avatar
Not to over simplify this. ( I might be looking at this all wrong) Couldn't you just get a 340* oil temp gauge and a 1/8 npt sendor, tap the upper vent hole, put the sendor in, run the sendor wire and a ground through the transom to the gauge???
Rookie is offline
Old 12-11-2008 | 12:24 PM
Rage's Avatar
Absolutely. I inquired about this approach with Livorsi. The potential problem is that of surviveability or lack thereof. The drive oil sensor cable kit was a heavily armored design for the environment at the external drive/transum area. See attached picture of the kit. The engine oil sensor is designed for the protected engine environment including exposed electrical terminations. Life expectancy and reading reliability of the engine oil sensor approach could be a problem over time. One could do their best to seal it up and armor it better.
This approach could still work very well for temporary installations to evaluate drive temperature versus operating conditions and test drive shower performance baselines.
I was first considering re-threading the oil sensor to mate with the drive vent threads and gasket surface if the sensor had sufficient metal available which I had not yet confirmed.
Rage is offline
