Whipple Stage II 496HO >
Old 01-27-2009 | 04:50 AM
Default Whipple Stage II 496HO
Hi,
im from Germany so please sorry for my bad english.
I have a Baja 272 with a 2008 496HO, its the late model with the new cover.
All my friends who are using the old style 496HO have the problems with the black transoms, I do not have this problem. So my question is, are there any differences in the ECU on the old style 496HO and the late model ?
I would like to upgrade to the Whipple Stage II upgrade, looking forward to gain 1-2mph on my single engine Baja 272. Anybody here who can tell me some experiences about the Whipple Stage II ? Will the upgrade work on the 2008 496HO as well ?
Is the upgrade on the late model the same upgrade as it is on the old style 496HOs ?
Best regards,
Norman
Baja272-racer is offline
Old 01-28-2009 | 02:10 AM
Really nobody here who can tell me something about the Whipple Stage II ?
Best regards,
Normen
Last edited by Baja272-racer; 01-28-2009 at 02:11 AM. Reason: difficult language...
Old 01-28-2009 | 08:03 AM
obnoxus's Avatar
Charter Member #1171
upgrade to CMI or Dana is a lil cheaper,,,,exhaust,,,, depending on the setup,,,, I have people gain 3 mph.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 01-28-2009 | 10:01 AM
Plum_Crazy's Avatar
Originally Posted by Baja272-racer
Hi,
All my friends who are using the old style 496HO have the problems with the black transomsNorman
I had this problem with my 2003 496HO's. I found out they never received a Mercury computer upgrade that resolved a fuel injection voltage issue. Have the serial numbers on the ECU's checked to see if they have the latest program. I sent mine to Mark at Precision Marine to get re-programmed. http://www.pmefi.com/
Plum_Crazy is offline
Old 01-28-2009 | 10:08 AM
The Whipple stage II program works well. Should pick up a couple of mph. However, it does require premium fuel. The stage II kit has much more aggressive timing and includes a colder thermostat to help prevent detonation. Available fuel quality is the key. Otherwise the stage 1 program will gain you a little bit and still run 87 octane.
Bob
bobl is offline
Old 01-28-2009 | 10:23 PM
My 2002 Baja had transom soot with the stock 496HO and still has it now with Whipple's Stage 2 - I'm going to install an 02 sensor/air fuel guage to try to find where it's running rich.
raeburn is offline
Old 01-29-2009 | 07:22 AM
Hi,
thank you for your replies ! Our fuel here in Germany starts at 95 or 98 octane, so this wont be a problem.
I thought that more guys here are using the Whipple Stage II on a stock 496HO ?!
When I could gain 1 or 2 mph topspeed it will be worth the money for me...
@ obnoxus: I dont want to spend that much money this year, even there is much more work to do when installing CMI´s, connect them to my Corsa etc.
Best regards,
Norman
Old 07-05-2009 | 05:24 AM
read about the different fuel qualities between Europe and USA, you will find that their 87 is similar to our 95.
Wiki it.
Oh and what psi does stage 1 and 2 run, and what hp?
richard is offline
Highmark
19
11-11-2020 01:21 AM
raeburn
24
09-03-2008 10:05 AM
boat4life
4
03-10-2004 11:07 AM
BillR
02-28-2004 12:05 PM
FAST ENOUGH
0
04-17-2003 07:26 PM
