Need help removing K-Planes. >
Old 03-16-2002 | 06:46 PM
blackhawk
Default Need help removing K-Planes.
The snow is melting and boating season is coming!!!
I need to remove my K-Planes from the transom of my boat. I have removed all the necessary bolts. The sealant used from the factory is very strong and I am afraid that if I "pull" them off it may take some of the gel coat/fiberglass with it.
Any hints or secrets for easier removal?
Old 03-16-2002 | 10:40 PM
yea I heard stories about 5200 great stuff if you don't have to remove, outher wise could loose gelcoat.can u work around the back plate and leave it on ?? also I heard of some stuff called kyptonight adhesive remover ? good luck James
FloridianSon is offline
Old 03-17-2002 | 11:43 AM
Cignificant's Avatar
I just removed mine to have them powdercoated. I just pulled like hell - nothing came off except the K-planes..
Cignificant is offline
Old 03-17-2002 | 09:46 PM
formula31's Avatar
try a length of piano wire, the thinner the better. Wrap your hands with something or wear heavy gloves and work the piano wire back and forth between the plate and the transom. Takes a while but will eventually cut through.
formula31 is offline
Old 03-18-2002 | 09:06 PM
In FLA. we use Anti bond for removing
3M 5200, I get it from Lewis Marine suppy
E-Mail if you still need help
scottf1-57 is offline
Old 03-19-2002 | 11:11 AM
We have always used a heat gun. When you warn the piece up nicely (maybe 120 deg F) you can remove it easily. DON'T let the heat cun hit the paint or gel. You don't have to be as careful on the powder coat.
I like the wire idea. Maybe heat and the wire for tough situations.
Ted
Ted Zoli is offline
Old 03-19-2002 | 11:44 AM
blackhawk
Thanks for the suggestions! I think I'll try a combo with the heat gun and the piano wire.
pullmytrigger
8
09-30-2004 10:08 PM
Vinny P
Checkmate
17
05-01-2003 06:49 PM
jbrauer
2
11-14-2002 06:44 PM
blackhawk
03-16-2002 07:12 PM
