SUPER CHILLER plumbing >
Old 02-09-2009 | 12:07 PM
Originally Posted by Young Performance
I've never had any troubles with the cold water hitting the hot intercooler. I have only seen my intake air temps get to about 120 deg at idle, which isn't very hot. As soon as you start to get the boat up, it will start shoving water through. I have seen them getting water at 15 mph. It all depends on the depth of the pickup and the height of both the strainer and the intercooler itself.
I'm just like you in that I did not want to rob water from the engine. I run my engines ice cold and want as much water as I can get. Also, like I said before, they just don't need it at idle. With the efi engines, puddling could be a problem. Since I'm using high impedence injectors, I can only get 65lb injectors. I have to run 10 injectors to get enough fuel on the top end. It makes it very touchy to control at idle. I have never run water through the intercooler at idle, but I think it would cause a problem with puddling. I'm sure I could tune it out, but why bother. You may not have that problem with the carbs., but I would still force feed it.
Eddie
Thnx BIG Daddy looks like force feed it is , will check Teagues and see what strainers and 3/4 pressure valves hes got ..1 good thing about running thru the pump is you can always tell if you have water thru the coolers and shes not clogged.
lookin at Teagues plumbing diagram they have 2 dumps, 1 inlet,1 pressure we have 1 in and 1 out and will put the pressure valve on the strainer to help with the spikes
Old 02-09-2009 | 12:22 PM
Shouldn't you run the water through the intercooler strainer first before the intercooler?
That was the only thing I got confused on, or am I just reading you wrong?
jeff1000man is offline
Old 02-09-2009 | 12:24 PM
Put either your pressure relief or the dump on the side instead of the transom and you may be able to see it to be sure it is flowing water.
Otherwise, you got the plumbing right.
Young Performance is offline
Old 02-09-2009 | 12:34 PM
strainer , pressure relief valve, cooler
Old 02-09-2009 | 12:59 PM
Was my idea that stupid ???????
DareDevil is offline
Old 02-09-2009 | 05:16 PM
Old 02-09-2009 | 11:09 PM
HotPursuit's Avatar
That is the way I plumb all of them. I never run water through the intercooler at idle, only while the boat is on plane. There is no need to run water through the intercooler if the engine isn't running hard. Force feeding it works great.
Eddie
Yup me too!!! Needle d*ck ya wasted 3hrs of my hear and still get the same answer!!! Your cut off..
Also Mr Running Hot you can run a blower without a intercooler to 6-8 #s of boost just depends on your intake ait temp and EGTS.So idling wont hurt jack,,, Stop typing and get that bad boy running!!! and order some props
Wazzz up Calmation bro ya going to miami?? That Skater came out awsome!!!!
HotPursuit is offline
Old 02-09-2009 | 11:13 PM
Originally Posted by RunninHotRacing158
OK OK just drink some more on my tab .LOL
$hit i won't make it to the races ,,,need to sell the baby now !!
Old 02-09-2009 | 11:16 PM
HotPursuit's Avatar
Also 12 years of force feeding my intercooler with no strainer and no pressure relief.No problems seems to me trash only happens around the dock when your idling so no trash or sand with force feed.Cant hurt to install a strainer and a relief but I always flush mine backwards after I flush the engines..
Old 02-10-2009 | 04:24 AM
Thanks Keith. Can't make Miami.....too busy. I would love to go but I just can't get away long enough. These engines aren't gonna put themselves together. You going?
