What size Bravo 1 prop? >
Old 03-17-2002 | 12:50 AM
Ghia's Avatar
Default What size Bravo 1 prop?
I'm currently spinning a 23" 4 blade Offshore prop( which I just found out is an outboard prop and shouldn't be on my boat. Gotta love my dealer) on my 2000 Stingray 230 SX 454 MAG. I'm running 68-71@5000. I'm gonna pull off the restrictive silencer tips and change to a Bravo 1 four blade. What size should I run to take the best advantage of the xtra HP I hope to gain? Also, what effect does prop diameter have on RPM at WOT?
Ghia is offline
Old 03-17-2002 | 09:14 AM
Cool prop size
you should be able to pull labbed 24 pitch bravo with your set-up!!! bill
wild willy is offline
Old 03-17-2002 | 04:43 PM
liquid asset's Avatar
Yep labbed 24'' is the way to go, smaller diamater = more rpm
liquid asset is offline
Old 03-17-2002 | 07:43 PM
1Boatnut's Avatar
If possible go to your prop shop and ask to try different props. My prop guy lets us use them obviously in hopes we will buy 1. Try a four blade 1st, I did not like it on my boat.
1Boatnut is offline
Old 03-18-2002 | 12:06 AM
R Addiction's Avatar
AT Cult Member #3
Bravo 24p should do the trick. Brother in law had a 220SX stingray with the 350/300hp small block in his and it FLEW! Of course that was 2 years and 2 boats ago. Good luck!
R Addiction is offline
daqcraig
14
03-05-2007 08:37 PM
Fast Willy
Prop Talk
2
08-28-2006 07:40 PM
Mikey Likes It
Prop Talk
2
04-03-2006 09:25 PM
redbuddy
2
08-25-2004 11:07 AM
Sunsation 32
09-18-2002 10:04 AM
