Counter-rotating engine?????? >
Old 02-16-2009 | 08:59 PM
Originally Posted by 302Sport
yeah the boat i am talking about has a counter-rotating engine but I am wondering how you can change the set-up and run two standard engines??????
I believe even the blocks are a little diffrent on the sealing ends. So i don't know !!
If its fine ,just leace it . Or rebuilt it like it is as a counter rotating one.
Or sell it and stick an other one in ?????
But even better if u take them both apart at the same time ,,,U FIND OUT WHATS DIFFRENT !!! LOL
And if you do ,,let us know .
PS.: like i said befor to you,,,KEEP YOUR BOAT,ITS AWSOME !!!!!!!!!!!
DareDevil is offline
Old 02-16-2009 | 09:00 PM
bowtie's Avatar
Borg Warners can turn either way, you just rotate the valve body 180 degrees to change rotation.
bowtie is offline
Old 02-16-2009 | 09:03 PM
thanks bowtie, then i have to ask why would people go through the trouble of having an oddball motor in their boat when they can just change the tranny around????
302Sport is offline
Old 02-16-2009 | 09:05 PM
I had no idea that the BW could be set up for reverse rotation. Se... ya learn something new everyday.
Darrell.
DMOORE is offline
Good ?????
Darrell.
DMOORE is offline
Old 02-16-2009 | 10:55 PM
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
There are several ways to do this.
A standard chain drive and a reverse rotation cam, or a gear drive so that you can use a standard rotation cam.
Counter rotating cam requires a different distributor gear, some say rear main seal and a starter.
BW just needs the pump flipped they say.
Rik is offline
Old 02-17-2009 | 03:00 PM
Steve H's Avatar
artselectricinc.com
It is my understanding that most if not all BW trans can not be ran in reverse. Maybe it is just the older ones? Reverse rotation engines are a rarity anymore. I am running twin disc gears and one is ran in reverse with older Arnesons. Seems to work fine.
Steve H is offline
Old 02-18-2009 | 11:06 AM
The velvet drive can have the pump indexed to run standard or reverse rotation. That trans rotation has to be the same as the engine rotation, ie you can not run a velvet drive in reverse at full power. Most twin inboard engines are set up this way, one standard, one reverse rotation engine with trans pumps indexed accordingly.
The boat you're describing was probably setup prior to the widespead availability of transmissions like the Hurth, BW 5000 series, etc that can be run in both directions on a standard rotation engine.
And as Rik pionted out, some arnesons are availale with a drop box that is chain or gear driven that change he prop rotation. This allows for 2 standard rotation engines.
rdoactive is offline
BajaRunner
06-19-2005 08:11 AM
Julio
6
12-21-2004 06:38 PM
Hiflier
5
07-01-2004 06:19 PM
PSYQUATIC
3
03-22-2002 09:13 PM
PSYQUATIC
03-19-2002 03:44 PM
