Question about replacing exhaust manifolds...
There are two ads on OSO for Gil Manifolds and tails. One add is for 2 sets off hp500's. The other sets are off of 500 Bulldogs. Will these work on a boat with trs dimensions ? I was thinking the bravos exit lower than the trs. Trying to get away from reversion problems. Any other options or advice?
Only the Best Will Do!
The Bravo tail pipes exit at a 14 degree down slope and are much shorter than the TRS tail pipes. Usually they are pointing in a far lower exit location than a standard TRS used. If your TRS pipes had quite a bit of downslope they may work. If your existing hoses are very flat you more than likely will have problems.
mslitti
General Racing Discussion
1
02-21-2009 09:58 PM
mslitti
02-21-2009 12:11 PM
