Drive alignment, toe in or toe out?  How much? >
Old 03-26-2009 | 05:00 PM
blue thunder's Avatar
On a twin engine vee spinning in, the props attempt to walk down the vee created in the water by the hull. This is why "in" give bow lift. This also causes the props to try to walk towards each other. In this case set the toe "in" at 1/8". That is the shaft tips closer than the nose tips.
For spinning out on a vee, reverse everything above. That's how it is boys on vees.
BT
blue thunder is offline
Old 03-26-2009 | 05:36 PM
Originally Posted by AO31
Yes I do. I guess torque has a way of moving things!
Absolutely
Old 03-26-2009 | 06:03 PM
BT
Thanks for the clear info there, now I think i understand "why" spinning in raises the bow.
What I do not understand is what causes the ill low speed handling many folks are concerned about when spinning in?
Greg
point92mach is offline
Old 04-16-2009 | 03:49 PM
tomtbone1993's Avatar
any ideas on a triple set up?
tomtbone1993 is offline
Old 04-16-2009 | 04:24 PM
The center one perfectly straight the the outhers toe in about 1/8 of an inch !!!!
DareDevil is offline
Old 04-16-2009 | 05:00 PM
Greg
My take on it is that whichever drive is in reverse,
prop thrust is being thrown upward against the
transom in the area between the drives, thus
reducing useable thrust.
I've found that trimming the drives up slightly
past positive helps a bit.....it helps route the
thrust back under the boat.
JaayTeee is offline
Reckless32
Sunsation
16
07-06-2006 06:13 PM
rv
3
05-20-2006 08:30 PM
Monty
10
07-15-2004 01:15 AM
formulaF302
2
06-10-2003 10:55 PM
Raypanic
Powerquest
1
05-22-2002 08:36 PM
