Is there an easy way to seperate eng from trans >
Old 03-20-2002 | 10:03 PM
Default Is there an easy way to seperate eng from trans
Best way to pull eng from a boat with speedmasters it has a motor mount plate inbetween the eng and bellhousing that has the twin oil coolers in it are there bolts inside the oil coolers. Plenty of room to work around the trans in the boat can I leave it in the boat or is it faster to pull it all.
fstboater is offline
Old 03-21-2002 | 06:56 AM
Mbam's Avatar
Offshoreonly Advertiser
There are bolts inside the coolers, probably better to pull the whole thing
Mbam is offline
Old 03-21-2002 | 09:28 AM
There may be one inside the opening for the top mounted starter too. Spent 1/2 hr trying to find that one.
Just pull the trans with it.
Gary
Gary Anderson is offline
Old 03-21-2002 | 03:47 PM
MrCIG's Avatar
Charter Member#330
Pull it all together its eaiser to put back in also. You just need to pull the drives also. when reinstalling
MrCIG is offline
dmaxx3500
Do It Yourself, Boating on a Budget
4
07-09-2008 06:40 AM
handfulz28
2
03-11-2008 04:39 PM
Wally
6
06-27-2006 08:22 AM
SeaDated
Mid Atlantic US
13
11-05-2002 10:29 AM
hystat
2
05-27-2002 05:35 PM
