Sea Strainer >
Sea Strainer
Sea Strainer
Old 10-21-2009 | 08:42 PM
fireboatpilot's Avatar
RIPSTA Racing Team
I don't know about the one your interested in but I still have the KPM unit available mentioned above. It's on ebay now. Look under member fireboatpilot items same as here on OSO.
fireboatpilot is offline
Old 10-23-2009 | 09:11 AM
I run the harden's and they work good, no wingnuts to drop in the bilage. Just make sure you put in shut off valves .
Jeff P31 is offline
Old 10-24-2009 | 08:35 AM
where can i find stainless fittings,,,,1-1/4in with threads on both ends,,,i need a fittings to go from sea strainer to ball valve,,,,catalogs dont show any???
TWIN-SPINS is offline
Old 10-25-2009 | 10:05 PM
Default Stainless Nipple
I found all the stainless fittings I needed to plumb my strainer at Mainland Valve in Houston, TX. The rep I dealt with is Tim White. Stainless nipples are just a few bucks each. The contact info is:
MVF, Inc.
Mainland Valve and Fitting, Inc.
9031 Monroe Rd.
Houston, TX. 77061
1-866-894-4343
O - 713-910 6540
F - 713-910-6548
www.mainlandvalveandfitting.com
smcclay is offline
Old 11-25-2009 | 08:49 AM
Default Sea Strainer
Originally Posted by Uncle Dave
Whichever you choose make sure you add a flush kit.
This will make your life much easier.
UD
Can I add a flush kit to my existing Livorsi (Teague) 5" strainers? Will this allow me to flush particles out into the bilge while in the water?
Balaboys is offline
