Props spinning out getting on plane >
Old 08-04-2009 | 08:59 PM
Ok, the do have vent holes. 3 on each prop that are not covered with anything. Heres a few pics I just took of the props.
Brandon is offline
Old 08-04-2009 | 09:00 PM
Will the vents still aerrate the props any since I don't have any exhaust running through the drive?
Brandon is offline
Old 08-04-2009 | 09:05 PM
Rookie's Avatar
They could still bring in some air. You have 2 RH props? you could get a LH prop and just switch the cables on your throttles. A Bravo can spin either way. I thought that you had Alphas because a lot of twin Alpha boats both props spun RH.
Rookie is offline
Old 08-04-2009 | 09:12 PM
Yeah, I knew you could do that, I'm just not sure how to. I figure whenever I have to buy a set of props I'll end up doing that though. Now I guess I gotta get some plugs for the vents also to give that a try. Thanks alot Rookie (and everyone else!) for sticking in there with me on this. Hopefully we get it figured out soon.
Brandon is offline
Old 08-05-2009 | 12:07 PM
Registered User
Originally Posted by Brandon
Its also straight thru hull exhaust, no captains call etc... so no exhaust runs through the drive/prop what so ever.
That depends on the type of exhaust bellows you have between the lower unit and bellhousing. If you have the open ended bellows or no bellows at all air will get pulled through the passage and down to the prop as you come up on plane. I have thru hull exhaust also and had that problem on my boat when I switched to an "over the hub prop" (Mercury Chopper), so I got a cap plug and capped the exhaust passage in the lower.
Marco
Holeinthewater is offline
Old 08-05-2009 | 12:45 PM
Marco
Good call, I never thought about that. I'll check later and see what I have. Thanks!
Brandon is offline
