Imco Powerflo manifolds >
Old 03-21-2010 | 09:19 PM
Default Imco Powerflo manifolds
Removed mercruiser manifolds and installing a used set of Imco Powerflos. The mercruiser had hoses in the risers,the Imcos do not. Cap the holes on the gooseneck assembly or have 2 bungs welded into risers? Appreciate any advice. Thanks Gus
BadCompany is offline
Old 03-21-2010 | 10:50 PM
fireboatpilot's Avatar
RIPSTA Racing Team
Pretty sure the power flows have bungs in the lower front of the manifolds and the water passages into the risers are internal from what I can remember from some I had awhile back. Just be sure you use new gasgets from Imco, their a light green color, just go on their site.
fireboatpilot is offline
Old 03-21-2010 | 11:14 PM
Default Fixx
Two ways of plumbing it, if you have a four port thermostat housing you either have to change it to a two port housing
http://www.iboats.com/Thermostat-Hou...view_id.222066
or you need to run the two into a y connector..heres a diagram and eddiemarine.com sells them,the y is on the port side of the diagram.
http://eddiemarine.com/techsupport/a..._plumbing1.pdf
FIXX is offline
Old 03-22-2010 | 02:01 AM
If your risers do not have bunges to tap in the hoses, then use one of mrfixall's options. The only problem I see is that the holes in the imco's between the risers and manifolds are not that large. I would install a water pressure guage to make sure you are having any high water pressure issues.
Griff is offline
Old 03-22-2010 | 01:04 PM
Thanks to all. That should get me on the water soon. 70 yesterday and 35 and snow today. Hurry up baoting season! Global Warming!!! Gus
