Fuel injector flow rate >
Old 05-04-2010 | 04:40 PM
Default Fuel injector flow rate
Hi,
does anybody know the flow rate (Gph) of the original Injectors from
the 1995 Merc 502 Mag EFI.
I need to find out the next bigger size
Thanks in advance
Hans
Scarab28Germany is offline
Old 05-04-2010 | 04:42 PM
JasonSmith's Avatar
44lbs I believe.
JasonSmith is offline
Old 05-04-2010 | 10:09 PM
Delphi# LBS/Hr cc/min grams/min PSI Imp
17113738 50 525.5 378 43.5 HIGH
17113739 40 420.4 302.4 43.5 HIGH
17113741 55 578.1 415.8 43.5 Low
17113742 75 788.3 567 43.5 Low
17113743 85 893.4 642.6 43.5 Low
17113744 96 1009 725.7 43.5 Low
17113812 30 315.3 226.8 43.5 High
17113813 42 441.4 317.5 43.5 High
17113814 65 683.2 491.4 43.5 Low
17113841 55 578.1 415.8 43.5 Low
Of course they will flow greater based on rail pressure but don't go crazy
You engine used the 17113739 as the stock part number
tunertech is offline
Old 05-05-2010 | 06:04 AM
Oh wow,
thats great, suuuuuper
Thank you very much
best greatings from Germany
Hans
Old 05-05-2010 | 12:26 PM
What do you mean by the high and low comments on the input prssure?
Boat1 is offline
Old 05-05-2010 | 12:36 PM
Ted G's Avatar
That is IMP = Impedence
High or Low means the resistance reading fo the electrical coil in the injector. Great chart BTW!
www.cbpba.com
Ted G is offline
Old 05-05-2010 | 01:19 PM
BUIZILLA's Avatar
instigator
what pulse width was used to determine this chart?
BUIZILLA is offline
Old 05-06-2010 | 10:17 PM
Default Pw
The data represented is at standard flow based on a continous flow. More to the point there is no pulse width factor they are switched ON.
PW relates to a timed trigger event from your ECU.
