How much HP do you guys think >
Old 05-07-2010 | 08:57 PM
KAAMA's Avatar
Originally Posted by jeffswav
Gotta be at least 800HP.
Yes, I agree. I saw a 565cid tunnel ram, one of RMbuilder's mild hyd roller, AFR 315 CNC ported heads, and 9.3cr make about 720hp @5400rpm on WESCO Dave's "crying towel" dyno with all pullies/accessories running and all.
Soooo.....this is just a guess gang, but I would say more like 850hp minimum---and probably a little more if it had Dominators. But hey, what do I know....I just kill bugs for a living.
KAAMA is offline
Old 05-07-2010 | 09:13 PM
I think 800+ with about the same # in tourqe !!!!!
I would not go with dart Pro 1 or tunnel ram and i hate B-max ..but thats the # u end up with.
How i know..building almost the same engine !!!! LOL
DareDevil is offline
Old 05-07-2010 | 09:44 PM
I have almost the exact same setup except for afr 357 heads and it made 802 @ 6500 oh yeah and a single dominator on a brodix sonnys intake
Smoothsix is offline
Old 05-07-2010 | 10:01 PM
racinfever's Avatar
850 with the right tunnel ram
racinfever is offline
Old 05-07-2010 | 10:19 PM
Rookie's Avatar
Rookie is offline
Old 05-07-2010 | 10:30 PM
Its gonna honk.
Valako does good work.
870
another question - What will it idle at?
Uncle Dave
Uncle Dave is offline
Old 05-08-2010 | 05:23 AM
Dennis,
What time are you guys heading down? I just tried calling Jim but his message box is full. I kind of wanted to head down but wanted to see what time you guys were going to start yanking on that big hog. LOL... I'm about two hours north. If you get this before you head out today let me know.
getrdunn is offline
Old 05-08-2010 | 06:03 AM
The HP 950 carbs (830 cfm) are not going to get you over 800 HP. Check vacuum at WOT and you will most likely be above 2 inches. I bet you would need Dom 1250's with that combo, unless we are talking daul qauds here.
brian41 is offline
Old 05-08-2010 | 08:21 AM
Brian,
He's running dual 950's. I realize the 830 cfm ea. but don't you think he would be OK with two of them. Regardless checking vac at WOT is a good point.
getrdunn is offline
Old 05-08-2010 | 08:28 AM
With duals he has more than enough.
brian41 is offline
