How much water presure is to much ?
That is too high..i would bring it down to 25 max..
But also i heard rev. a 598 over 5800-6000 is deadly !!
U may wanna run a little bigger prop on that engine to bring the RPM down and u should not lose any speed !!
But i would install the relief valve after the pump !
It should be ...oilcooler > pump > engine ...
or is your oilcooler behind the pump ??
I used a block drain for the gauge, I have no oil cooler we run on pretty small lakes and oil temp has never been an issue. So I should install a t after the sea water pump with a relief valve to dump overboard, what size line ? I have one of those brass ones from teage
The oil cooler itself should help bring the press down a bit ..since u don't have one in there that may be the key !!!???
Also i take my water press from the top of the intake.
Fuel press...( N/A engine ) 7-9 PSI
Water press 17-25 PSI
Oil press 75-85 PSI
water temp WOT 140-165
oil temp WOT 190-225
i had the same problem so we put a restrictor plate where the water thermostat goes with a smaller hole. it controled the h20 pressure but still had problems because the h20 pressure entering the boat was still to high as it kept blowing the hose off between the outdrive and the engine. to finally solve the problem we welded the water intake slit on the imco lower outdrive closed to about half the original size. my 2 cents.
