zero effort shifter cable installation >
Old 06-28-2010 | 08:33 PM
Default zero effort shifter cable installation
How do I connect my cables to the zero effort throttle/shifter? I have 33c cables and I do not see how they connect. Where I would think the cables should attach there is only a pin that goes through the bottom of the shift lever. Am I missing something? Any tips?
endeavour32 is offline
Old 06-28-2010 | 09:20 PM
Rookie's Avatar
Yeah I have been wondering the same thing. Can some one post a pic of the actual 33c cable end that I need.
Rookie is offline
Old 06-28-2010 | 09:22 PM
Well I'm not the only one.... This is frustrating, when I ordered my cables from Eickert they said I didn't need anything. There has to be some sort of adaptor as I see no way to get that treaded end in and secured.
If you follow this link and look in the picture an #40 I'm taking a stab in the dark that this is the cable connection. However there is no part number for it?
http://www.crowleymarine.com/mercury...ts/2443_30.cfm
I see that your using the same trim switch that I am.. are you going to run the wires inside or outside... I have mine inside now but I'm afraid they may jam something.
Old 06-28-2010 | 09:41 PM
Rookie's Avatar
I just took mine apart. Apparently you must knock out the pins and use the standard cable ends. I will just make some at work. 10-32" thread
http://www.go2marine.com/product.do?no=63628F
Rookie is offline
Old 06-28-2010 | 09:53 PM
Those are for the shifter and the carb. I have that package. I think #40 in that diagram is our missing link!
Old 06-28-2010 | 10:02 PM
Rookie's Avatar
That's the Basstard!!
Rookie is offline
Old 06-28-2010 | 10:03 PM
Ted G's Avatar
You need the #40 connector. It is actually a hook, not a loop. You leave those pins in place, hook the pin and then secure the cable at the bottom. As long as the cable is secure, the hook will stay in place as the cable basically pulls in a straight line. Here is a better parts list from Mercruiserparts.com . #40 is listed there (and not cheap )
http://www.mercruiserparts.com/Show_...%2C+Components
www.cbpba.com
Ted G is offline
Old 06-28-2010 | 10:06 PM
good grief that's a rip off! Thanks for the better parts list... Looks like I need to go to the marina and order more parts tomorrow!
Old 06-28-2010 | 10:16 PM
Rookie's Avatar
$34.56/ea LOL! I'll make a few in the next couple of weeks and just live with my Morse controls for now.
Rookie is offline
Old 06-28-2010 | 10:51 PM
c_deezy's Avatar
Yep that's it. You need the 'hook'
c_deezy is offline
