Question about ignition module >
Old 10-05-2010 | 04:59 PM
Strip Poker 388's Avatar
Rob
I bought the CRC dielectric Greece and coated the plug and 2 post, after about 40hours its green,wouldnt even fire up.pulled it and cleaned it fired up then.
some more info http://www.megamanual.com/ms2/GM_7pinHEI.htm
Strip Poker 388 is offline
Old 10-05-2010 | 05:34 PM
Default Gm Icm
Originally Posted by Greggcellent
Thx guys fo the part numbers . I wonder if those will be Ok as far as the rev limiter goes ?
You do not have to be concerned with rev limit. The ECU takes control of rev limit.
tunertech is offline
Old 10-06-2010 | 06:47 AM
the GM est dist like the module somebody posted have a special "marine" module with a specific timing curve and some(like mine) are designed to run without a computer, a std one will not advance, tried it a few years ago..
ezstriper is offline
Old 10-06-2010 | 04:33 PM
Ebay Ed's Avatar
i have a complete used Gen VI EST Distributor listed in the swap meet i was chasing a problem with my boat and replaced the distributor to find out my fuel pressure regulator was bad
www.bajaboatowners.com
Ebay Ed is offline
Old 10-10-2010 | 09:56 PM
Thx So Much guys for the replys,,,,, I haven't had a chance to pull the Ing. Mod. yet and am hoping to get to that this week sometime. I will check it out and try to respond to the replys.
Greggcellent is offline
