Merc 600SCi, Noise reduction >
Old 11-15-2010 | 03:37 PM
Default Merc 600SCi, Noise reduction
Hello,
I need your advise:
I want to have a single engine boat built with a Mercury 600SCi.
What kind of switchable mufflers would you use? Once switched on they really should get the engine calm.
Are there other possibilities you would suggest?
Merc's XHaust is way too expensive...
Thanks for your help,
Heiko
frogger1403 is offline
Old 11-15-2010 | 06:45 PM
i wouldn't use a switchable exhaust with that horsepower. it would only be good at idle. I used CMI's sound advantage clamp on mufflers and they worked great.
Advantage 575 is offline
Old 11-15-2010 | 06:51 PM
Drew marine shot guns, quit at idle
fastscarab22 is offline
Old 11-15-2010 | 07:49 PM
I wouldn't say quiet at idle, but they do help. Probably 5 db or so quieter at idle.
Griff is offline
Old 11-15-2010 | 08:32 PM
close, ( what did you say , i cant hear you )
Old 11-16-2010 | 12:47 AM
Thanks, I can't find "sound adavantage clamp"
did you mean
http://www.custommarine.com/accessories/Silencers.php
the first one on this site?
heiko
